Hello to All 319 Enthusiasts
Finally after much researching and communications, my L319 is due to arrive this evening on Transporter.. I don't want to Jinx anything by being premature but I've waited this long (6 months) so fingers crossed..
It's a 67 model with the later diesel engine OM621 ? I think, Panel van and its got serious corrosion, particularly around the front A & B pillars and roof guttering..
Much as I'd like to be working on it, I'm currently building a workshop to house it properly ...
Much regards
Rob
L319 Arrival Across the Water
Forumsregeln
Re: L319 Arrival Across the Water
Hello All
A good day for me today, as I managed to spend a few hours on the Van, she now runs and moves under her own power. Had to work on the priming pump - new O ring, (if anyone know where you can buy one of these pumps new OM621 ??)
Currently just running briefly as the radiator has a hole in the matrix but the engine sounds pretty sweet..
https://youtu.be/fZaHlpEMgto
it's aliiiiiive !!!!!
good job and courage for the rust !!!
we can't make new with old .... but we try
Thanks Jim... I've seen worse I think
Removed the skeleton from the engine so it should smell better inside...
