Color of the enginecompartiment ??
Verfasst: 23.12.2007, 19:27
von frankbrus
For my new project O319
Hallo 319-fans,
Can you tell me what the original color is of the enginecompartiment ? :wink:
Is it black or is it in the same color as is the exterior color ?
grusse,
Frankbrus
Verfasst: 27.12.2007, 16:01
von zehbeh
Hi Frankbrus,
in my 319 the engine compartment is neither black nor in exterior color.
It is in light grey, the same color as the inside is. The one in the Mercedes Museum also is completely grey from underneath. At my 319 all the body parts except the outside is painted in grey.
But unfortunately I can't tell you the color code of this grey. I already called the MB Classic Truck Center an they asked the Mercedes archive, but they couldn't help me.
I used a color called Seidengrau (silkgrey) RAL 7044 what is very similar to the originally used grey.
I hope this helps,
paint
Verfasst: 28.12.2007, 10:07
von danny
Hallo, k'heb er nog eentje staan met de originele kleur erop is altijd grijs,denk dat het het meeste trekt op parelgrijs van vw L21,je kan altijd eens komen kijken,ik woon in temse
